Kitchenaid Frig Superba ice maker
Inventorgeorge
I am in need of the wiring diagram for the ice maker for Kitchenaid Superba Refrigerator model KSRB27QXBL01.
I have the ice maker out, and need to trigger the water value to see if it had failed, or the ice maker has failed. Water will not flow when the ice maker cycles.
The plug for the ice maker has 4 wires, black, white, yellow and green. I assume that I can connect two of them together to fire the valve solenoid, but I do not know which two.
I will then need to purchase either the water valve, or ice maker. Can you provide me with this information?
Thank you very much,
George
  • Replies 1
  • DurhamAppliance
  • Inventorgeorge
Your yellow wire is actually tan or should be tan....so with the icemaker out, jump black to tan to get water.
