LG LDS4821ST doesn't turn on
I have an LG LDS4821ST, serial number beginning with 808KW, and it won't turn on. At all. I press the power button, and I hear a click distinct from the noise of the button itself. (When I flip the circuit breaker, I don't hear that noise anymore.) The display does not light up. I noticed after taking the door apart then turning the juice back on, a wee red LED on the inside of the main board lights up when I hit the power button. It also appears that the glass fuse embedded in the silicone blanket is blown (meter did nothing when I put probes at both ends).
A few evenings ago, the dishwasher was started, then I went to bed before it finished and woke up to the non-responsive dishwasher. The bottom was full of turbid water and the soap dispenser had yet to open. So clearly it got to a certain point then conked out, but as I wasn't there when it happened, I have no idea what, if any, error code might have popped up.
My half-assed diagnosis is the main board is done for. So I suppose my questions are 1) Am I right so far?, and 2) Is the main board the root of the problem or a symptom of something else?
Thanks.
Start at the electrical connection box behind the kick panel (where the household electricity connects to the DW) make sure wire nuts are tight. If they are then proceed to follow the electricity and see where the disconnect is.
  • Like 2
billpartsch
Thanks for the response. The electrical connection is fine. I'm unsure of how to follow the electricity from that point. I have a multimeter and the wiring diagram, but I could use some pointers on where to put the probes. I'm keen to learn, so I welcome both direct help and/or direction toward sites/videos that illuminate the techniques involved.
I forgot to mention before, the main board number is Part number: EBR33469402
, which I've read elsewhere in this forum was subject of a service bulletin. Does this mean that LG will help offset the cost of replacing it, or is it just LG telling service techs to be on the lookout when customers report problems a malfunctioning main board might cause? Also, is the apparently blown fuse on my main board relevant? It does not appear replaceable.
Thanks.
  • 3 years later...
I had the similar issue that arose on our LG LDS4821ST dishwasher.  Just stopped working overnight.  I replaced the door latch and the noise filter assembly.  Two fairly inexpensive repairs, which were the two most prominent root causes.  The noise filter was a "crap-shoot", because there was no way of knowing it was bad, unless you pulled the dishwasher out of it's space to access it.  I figured since i had it out, I was willing to replace it either way!  Replaced both and still not powering up!  I checked the "fuse" on the Controller Board and it was good too.
Funny thing happened!  I accidentally pressed the power button while the door was open and the damn unit powered up!!!  Go figure...?  I pressed the power button several times and the unit powered up/down.  I closed the door, thinking that somehow the unit woke up and was fixed.  Nope!  Back to square one again and cursing to say the least!!!!
Any feedback from anyone on your issues??
MB
