Model :  WHDVH626FWW                           What am i missing ?  What else could i try ?
GE  Adora  Washer front load
Error codes: E70  ,48, 31 , 23
Symptoms:  Wont tumble or Rotate
Tests 1 (NA)  2(error codes) 3(NA)  4 (Pass) 5 (Pass) 6(Pass)  7(Pass) 8 ( Pass) 9 (Pass) 10(Fail displayed EE)  11(fail  displayed “0”)  12(Pass)  14( 1st attempt  passed but all other attempts up to now have failed)
Ohms Readings from control  board : P9  two yellow wires 116  Ohms
Motor readings :     Ohms      Blue to White     6.5
                                                 Blue to Red     6.3
  All attempts to test voltage (test 10,11,14) at harness  Blue /Red wires ( after control board and before inverter) have failed and two beeps sound.
Pulled the inverter/flipped it over/ cant figure what to test? / I did an Ohms reading on the harness (female that connects to motor) Blue to Red  Blue to White ect and doesn’t read anything.
  • sam sam
  • Samtech
E70 = a stuck key, continuous key signal for 60 seconds. But T04 is the key test and you passed that.
E48= drive motor, which will cause you to fail T10, T11 and T14.  But you ohm'd out the motor and it seems ok.
E31= drain time out, But you passed T5 which is the drain motor test.
E23= flood protect drain . Foam switch closes in idle state. Measure the wires connecting to P6  (4 & 5) it should show an open (no continuity) if it's shorted replace the pressure sensor , if it measures open, replace the main board.    Good Luck.
Ok , I bought new main board . Entered my machines code, Entered test modes and ran T10 (result EE)   T11 ( result 0)  cant find T14 . Whites wash mode + start shows the machine start to turn the clothes , but after that nothing.   During Rinse and spin cycle .... rinse  (no movement ) Pump works.....Spin cycle (Nothing)    Whats your thoughts ??  Thanks, Sam
