looking for technical info for Dacor ESC130SCH wall oven. Thank You!
  • Replies 9
    5
  • IgorY
    5
Not a valid model number. Please validate all model numbers at an online parts site, like RepairClinic, before posting a request.
On repair clinic it finds it by firest part of a model number
ECS130
but the full number is
ESC130SCH
The complaint is that broiler is not working. Was hoping to take a look at tech info :)
 Copy and paste the model number exactly as you posted into the repair clinic search box. You will not find anything,  even if you just use the first part of the model number.
 The big model number you posted is correct. Now compare with your original model number. Do you see your mistake?
Sir yes sir :bangin:
 The lesson here is that had you posted the correct model number at the outset, you would've had the technical information that you were seeking already. As it is, I'm out on the road and unable to get that for you at this moment. So it is to your benefit that you validate the model number before you post a request  because this helps ensure that you get the technical information you are seeking quickly.
roger that
Search the Downloads section for "ECS*" and you'll find several goodies I've uploaded for you.
Thank You!
