Maytag Atlantis washer MAV7600AWW won’t drain or spin
Hello Experts-need some help please.  My washer won't spin or drain, it works fine in all other was cycles.  I've changed the thrust bearing and it still doesn't spin, rinse or drain.  When it gets to the spin cycle the timer counts down and nothing else happens.
Please help.
Anthony
The first thing you need to do is see if the drain pump is getting voltage.  If you don't have a volt meter you can usually tell if it's getting voltage by listening for a hum (jammed pump or bad pump motor) or feeling for a vibration.  The machine will not spin until it drains, therefore you need to first find out why it won't drain.
