Budget Appliance Repair Posted March 4, 2016 Posted March 4, 2016 (edited) Looking for the mini-manual or wiring diagram for: Kenmore electric range Mod# 911.93612010 Ser# 1M299090Q Mini-manual number: 31-13657 Thanks, Edited March 4, 2016 by Budget Appliance Repair
Team Samurai Samurai Appliance Repair Man Posted March 4, 2016 Team Samurai Posted March 4, 2016 Plucked just for you, Willie:
Budget Appliance Repair Posted March 5, 2016 Author Posted March 5, 2016 Thanks Samurai, going out on this one today - Was hoping for a complete wiring diagram. Maybe it is on pub# PART NUMBER: 31-10415 Instruction, none of the items on the parts list say wiring diagram - I thought it would be on 31-13657 but it has everything else I needed but a complete wiring diagram. This one shouldn't be a problem without it with the info from the 31-13657 technical instructions.
Team Samurai Samurai Appliance Repair Man Posted March 5, 2016 Team Samurai Posted March 5, 2016 I can't find anything with that PUB number but if you give me the part number you're replacing, I may be able to find it.
Budget Appliance Repair Posted March 6, 2016 Author Posted March 6, 2016 All is good, bad info from tenants. They said oven not heating correctly, elements only getting a little warm and couldn't tell me if broil worked OK or not, (I was looking for a schematic because I thought they meant either or both elements in oven only a little warm so was looking for something in common with both). Just ended up being a burnt out bake element, (small hole blown out bottom with no major signs on oven cavity and no bubbling of element so not easily seen. Broil element was causing the little bit of heating as it cycles on/off during bake).
