I have a GE Adora front load washer and it wont spin. I received and   replaced main board but still wont spin.  Power seems to be coming from board down to inverter, but nothing to motor harness . How do I test the inverter ?  Or could it be something else . Thanks , Sam
Test specs  :   T 10 (EE)
                       T 11 ( "0" )
T 14 ( cant find on new board)
Spin and rinse cycle ( Starts to rotate)
  • Replies 4
  • sam sam
  • vee8power
  • coolhandluke
Did you set the model ID in t01?
yes
coolhandluke
Check if the inverter board is receiving 120vac when needed, if OK check motor, disconnect harness and check winding at motor connector, should read,  Blue to White - 6 Ω,  Blue to Red - 6 Ω and White to Red - 6 Ω, the sensor has a resistance value of approximately 118 Ω between the two orange wires, if OK replace inverter board. I downloaded TECH GUIDE in POT LUCK.
Edited by coolhandluke
additional info
 spin rinse cycle ....
1. ( "Spin" is reading  120v going to harness before inverter)
2. motor harness off ... Motor  readings  BW =(6 Ω ) BR=(6 Ω )  WR=(6 Ω )
3. I see 2 red leads on motor , they read  116-117
4. When you say "inverter board"   you mean the silver square unit before motor ?
