This washer is 25 years old and has been a workhorse, needing mostly minor repairs over the past 5 years - drain pump, motor coupling, etc.  I replaced the transmission about 4 years ago, but the motor is the original one.  The problem now is that water is left in the tub after the spin cycle ends and/or the clothes are still soaking wet.  Probably related are (1) The agitator column is very hard to spin manually - as you would do after adding detergent while machine is filling with water, before clothes are loaded; and (2) The washing cycle is loud with a bit of a banging noise.
Suggestions?
Thanks in advance ...
If it's spinning but the clothing is still too wet make sure it's draining properly. If it is you probably have a bad clutch. Check for grease in the clutch and check the wear on the clutch pads. Also check for a leaky trans, often they leak and get grease into the clutch causing it to slip.
Any grinding is usually related to clutch, trans or brake assembly.
Quote
That's hilarious!  Coming from an automotive background and reading this.
I don't get it.
