      12
What's the best GE Range Manual for this guy?
Thanks!
This one awwta git ya:
was looking for one with regular old wb20k8 thermostat.
That one has electronic controlled thermostat.
Yes, the model number you gave uses a computer board and RTD oven sensor-- no mechanical thermostat. See for yourself: http://www.searspartsdirect.com/model-number/36272221200/0582/0124002.html?searchType=modelSearch&prst=&q=362.72221200&searchTerm=36272221200&shdPart=
Not sure what to say.
What is part 17 on gas and burner diagram?
Samurai, look a little closer, not an ERC on back panel, just an expensive kitchen clock/timer!   Not used to control any functions of actual range.
16345Ed, this is a pretty basic range what kind of problem are you having that you think you might need a manual?  Start a topic in Kitchen forum, someone should be able to guide you in any disassembly or other questions.
It was a bad thermostat. Determined on my own.
However I was trying to be prepared and have proper manuals etc before going on a call. Plus in trying to get manuals loaded on my iPad as I come across models.
I'm good.
Btw I think that Sears parts diagram is wrong.
Go go to APP type in 362.72221200 and see what thermostat comes up.
Repair clinic is correct, Servall and Tribles as well.
Looking at the diagram on my phone while driving on the NY Throughway back to New Hampshire, I thought I saw an oven sensor.
Let that be a safety lesson to all: never look at parts diagrams on your phone while driving-- the screen to too small to see accurately in a moving vehicle. Use an iPad instead.
The part Sears site list WB20K10023 is a good replacement or sub, usually found at a much lower price, for the WB20K8 Oven t-stat.   It actually looks like most of part suppliers are now subbing the WB20K8 if you search for a WB20K10023, (Sears still shows the WB20K10023 in stock at half the price of the WB20K8).
Last time I ordered a few for stock, (DEC.2010 - still have one left), I was able to still get the WB20K10023
Aha, thanks!
