GE ADVANTIUM 240 MODEL SCA2001BSS 03
MY ADVANTIUM HAS QUIT HEATING.  EVERYTHING ELSE WORKS, LIGHTS, PLATE ROTATES, BLOWER WORKS AND UPPER AND LOWER LIGHTS HEAT.  ONLY MICROWAVE DOESN'T HEAT, ALTHOUGH IT SOUNDS LIKE ITS WORKING.  I DECIDED TO INVESTIGATE THE PROBLEM MY SELF AND TRY TO SAVE SOME MONEY.  I BELIEVE THE PROBLEM IS THE UPPER INTERLOCK SWITCH.  I TOOK A PIC OF BLACKENED WIRE GOING INTO INTERLOCK SWITCH.  DO I ONLY HAVE TO REPLACE THE SWITCH, OR DOES WIRE HAVE TO BE REPLACED AS WELL?
  • DEANOSHOME
  • LI-NY Tech
Cut off the burnt part of the wire and install a new terminal connector to ensure a tight fit and no arcing.
OK Thank you
