I've got an Amana ARS9269 counter-depth refrigerator that I bought in 2003.
Some years ago the ice maker, water dispenser, button control & display went kaput, possibly due to a lightning strike or some other weird power disturbance.
I haven't bothered to fix it because other than the ice maker and the non-responsive display, the fridge works fine. But I'm in a fix-it mode right now and am wondering if anyone knows of any shortcuts to figuring out which electronic component(s) or complete control board(s) I should replace to get it back to full functionality.
Here are the symptoms:
- The display lights up and displays full lines of text, possibly information from the last power outage( time, date, duration  etc). But there is no response from input to any of the 5 buttons.
- The water dispenser, ice maker, and night light do not work.
- The fridge and freezer function just fine.
Any advice?
-Matt
PS: I would also love to get a parts breakdown diagram with part numbers if anyone has them! Thanks!
  • Replies 5
  • MCALLAN
    4
  • lvasquez11
  • LI-NY Tech
What you need for this model is the "P" number.  Check the model number tag and find the number that starts with a P.  There are two different versions of this fridge.
It probably needs a new dispenser board, but it depends on the P number.  One is available, one is discontinued.
Sticker says:
Model # ARS9269BS,  MFG # PARARS9269BS0, SN 10287914AC.
Do you know part number of the dispenser board?
Thanks!
Here's a correction to my symptom list:
- The display lights up and displays full lines of text, possibly information from the last power outage (time, date, duration  etc). But there is no response from input to any of the 5 buttons.
- The water dispenser, ice maker, and night light DO work. But the ice crusher does not work.
use appliancepartspros.com for breakdown
touch pad - black Part number: 67002675
Edited by lvasquez11
thanks!
