Frigidaire FRS26R4AB5 Compressor Will Not Start
tony17112acst
I have a FRS26R4AB5 fridge where the compressor will not start:
* The Compressor will rattle/hum when plugging it in. It stops after about 10 seconds and then tries again later;
* The condenser fan and everything else that should be running works fine;
* I replaced the start relay and capacitor;
* I verified 130 volts going to the starter relay (2 wires);
* I checked ohms on the 3 pins of the compressor: 8 (bottom left+right pins), 5 (right+top), and 3.5 (left and top) ohms. I am under the impression that I should get 10,6, and 4 and I can't find info online if that alone means the compressor is toast.
(1) Is there anything else I can test?
(2) Is this enough information to conclude my compressor is bad?
Thank you very much (in advance)! -Tony
You do not have to have 10, 6, 4
Check resistance from each pin to compressor body, scrape paint off to do so, should be nothing. If something compressor is no good.
Yes, sorry
Edited by abaesemann
  • Like 3
tony17112acst
Thank you for your input!
I did sand the paint off in a spot and tested continuity to each pin and got no continuity.
I will have to look for used fridges. It's a shame because this is like new even though it is 10 years old. It is still beautiful and everything works except one thing!
Thanks again.
