Doesnt seem to be any reference in the archives for this machine so I am requesting a service manual for KENMORE 110.45089400 front load washer (or the Whirlpool equivalent).
any insight into an F 06 error?
Thanks however I already have the tech sheet.
I need a service manual for this or the Duet Equiv.
Any insights into cause of F 06 error?
That error code is in the tech sheet, tells you what could cause it.
F/06
DRIVE MOTOR TACHOMETER ERROR
The control is unable to properly detect motor speed and the machine
will shut down. If a failure occurs during high-speed spin, the door will
be unlocked after three minutes.
Possible Causes / Procedure
1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
