Was surprised not to find a manual for a 542 here. Could I please get a copy?
Thanks.
It's there... SubZeros searching sometimes may not  yield results.. I think it has to do with the" -zero"  part of the name.   In search terminology that means "leave out any results with the word 'zero'
try this search term   *zero 500
Anyhow,  here's a search tip for this or any manual.... don't just search the files search topics and it may also point you to the proper file.
 Lol I see you discovered the tip.... very good!  You're on your way to becoming a file finding master!
here's a test for you.... find the  subzero manual  for 600 series...manual part 2.... let me know whatcha  got.
Last night I did not have a model number so I searched Subzero and down loaded what was there. This morning I had the model number and just typed in 542 and I found it that way.
I also just searched files last night but this morning topics
Edited by Lighthouse
I found the 1 & 3 manual but as far as the # 2 manual I just found discussion about it.
It's there alright... and until we change it.. it's one of the most difficult manuals to locate... here it is
Now this one is tricky... I didn't know the job aid number... searching "sub"  or "sub*' doesn't work... using the tags from the other manuals did not work... I tried all combinations of words in the title... no go....
I think it all comes back to that little hyphen... for some reason with this title the hypen or minus sign seems to hide all the words that follow  from search... all the words until you get to the comma.  so the search term that brings this elusive  file up is "part 2"       go figure.
But this is an example of how being creative with your searching can yield results
It also exemplifies,  the time spent and how we rack our brains to find info for our brothers
and lastly  it explains the reason uploaded files have to be approved before becoming accessible.  If that file included "subzero" and "sub zero"   (expected search terms)   along with "sub-zero" (actual name) in the tags  or in the description it would be easily found. We are now being much more accurate with tagging and describing files.... it's better for you and hopefully we won't have to rack our brains as much to help you find a file.
Edited by DurhamAppliance
And all of your time and effort is greatly appreciated more than you know.
