This is a counter depth Side x Side GE refrigerator.    Ice maker makes ice, but then it melts.    That was the initial symptom.   My tenant said the food below was frozen, but when I went there and put an instant read thermometer in, the freezer was about 40 degrees.   It was set to 0.
Also - I just read that some GE refrigerators have a self-diagnostic capability.   Does this one?
If it does, where can I find manuals that might have the self-diagnostic instructions.
Thanks for all help...
Warm in both compartments, check these:
- Condenser fan running
- Condenser coil clean
- Condenser coil temperature-- should be around 100F
If all those check good, then you'll need to check the frost pattern on the evaporator coil.
Just a question, check condenser coils temperature? Why did I think compressor?
Edited by 16345Ed
Just now, 16345Ed said:
Just a question, check condenser coils? Why did I think compressor?
Don't know what you were thinking unless you tell me! Feel free to elaborate or ask a complete question.
I thought we checked the temperature of the compressor, didn't realize it was the coils we are suppose to check temperature on, just my misunderstanding and wanted to verify. Thanks
Correct-- condenser coils are where you check head temperature if you're looking for the rule-of-thumb 100F
  • Like 2
defrost failure will result in warm temps also...
Yes indeed, hence the next step being eyeballs on evaporator as Samurai stated.
After checking condenser...
