Kenmore 110.92580800 slams during spin cycle
On heavy loads she slams when spinning unless the clothes are perfectly balanced.  Is there a spring kit that needs replacing?
Serial# cd3515181
  • Replies 11
  • johnjohn
    7
  • sh2sh2
  • vee8power
  • Hiroshi
With the cabinet off you should see 3 short springs connected between the moving basket/tub assy. and the stationary machine base. The other long spring opposite the motor is there to counter the motor's weight. One of these could be broken or dis-connected.
All 4 springs are intact.  I assume the are just stretched?
Sorry for the reposts.  Will new springs solve the problem? Anything else I should replace while I have it taken apart?
Check the white suspension pads
  • Like 2
if it "slams" when it comes to a stop it is glazing on the brake pads inside the basket drive... a little silicone gel will fix that. Also there are three white "snubber" pads between the metal triangular frame that holds the washtub and the support tripod that holds it off the floor- if they are worn or damaged the washtub will be very squirrely!
4 spring and three white pads are orded.  Ill check the brake pads while I'm in there. Thanks for the help
  • 2 weeks later...
This pin fell out when I was under the washer.
Nothing to worry about, just a shipping pin from when unit was new
Haha ok. Thanks.
