                         Hi, I am looking for a service manual for this  Daewoo washer model number dwd-wd1353wc.  Do they make service manuals for Daewoo?  I have a washer full of water with the door locked . Thanks.
  • allen63
Drain the water out the pump cleanout port. You can manually release the door latch through either the top panel or from underneath (tilt at 45 degree angle to the side). Owner's manual has the schematic:
Bigger problem will be getting parts!
               Thank you, greatly appreciated:)
