My Advantium 120 is not powering up. Outlet plugged into is working. Display is black. Control panel unresponsive. Surface lights down. Is there an onboard fuse? Location?
Thanks for any and all advice.
  • Replies 5
  • ontherocks
    4
  • 16345Ed
Important Note: The primary interlock, monitor interlock, door sensing (secondary interlock) switches, and the relay board must all be replaced when the 20 amp fuse opens due to operation of the monitor interlock switch.
The unit is equipped with a 20 amp fuse (Part # WB27X10388).
The fuse is located in a receptacle near the top of the noise filter and is common to all functions and door switches.
Fuse
Note: If the fuse opens, it will disable all oven functions including the display. The oven must be partially removed to access the fuse. (See Oven Removal / Partial Removal.
Thank you 16345Ed! Is this a project a somewhat capable person can undertake?
Thank you 16345Ed
Uhit model number is SCA1000HWW 02
ordering parts you listed above. Your earliest reply mentions replacing the relay board. Is this another part I should order?
Thanks again for all your help!
Just realized the No Image part of your message was probably the relay board.
Sorry about that.
