I have a Whirlpool Cabrio WTW5700XW2 Vertical Modular Washer.  I noticed my clothes weren't fully spinning out on the final spin cycle.  I got error code F7 E1.  I performed the automatic and manual tests and everything seems fine while empty.  It spins on high speed perfectly.  I do hear a slight clicking noise at spin high speed.  I cleared the code and watched a load of laundry.  On the final spin of the load it completes a slow speed spin.  Then it switches to a high speed spin for the final drying.  As the basket picks up speed I hear a click and then it starts to wobble and then the lid lock starts flashing and throws the F7 E1 code.  After the click the basket seems to sway a lot, but I think it may be because the spin cycle stopped abruptly throwing the tub out of whack.  I have been doing online research like crazy and a lot of people say to replace the shift actuator.  I am happy to swap it out for $40, but I am not 100% convinced this is the issue.  The clicking noise at high speed leads me to believe it may be something else.  Any guidance you can provide is greatly appreciated.
  • Captain Dunsel
  • Stettbrone
List of what might cause an F7 E1 Error Code
VMW calibration
Control not sensing the basket movement
Mechanical friction between basket and tub
Belts is off,or pulley is loose
Weak or disconnected motor capacitor,or broken wires to capacitor
Harness issue between control & shifter
Shifter malfunction
Motor malfunction
Main Control
Most likely Shifter.
I appreciate the response.  I just ran the machine empty without issues and no clicking sound.  It seems to only have an issue with wet cloths in it.  I will replace the shift actuator and go from there.
It is aways a good idea to do a VMW calibration after doing anything to these washer.Even if you change the shifter.It tell you how in the Tech.Sheet. Only takes a couple minutes.
