whirlpool duet washer fails c:06 error
i have a whirlpool duet washer model ghw9100lw1.
I was getting an f02 error, cleaned a small amount on goop from the filter and ran the washer again with the cover off. I  noticed the drain pump was pretty loud so I replaced it. while I had the pump out I took the drain hose off the tub and cleaned a fair bit of goop out of it. still not working properly. when I run the diagnostic test it drains the tub and the pump runs util it times out and fails c:06.
what's next? the pressure switch.
C:06 is still drain pump
is there power to pump?
check all wire connections for good contacts  (DP2 1 and 2 on CCU)
check wires for continuity
likely need new board but make sure you do your tests
Good luck
Make sure pressure switch hose is not clogged, disconnect at switch and blow down into tub
  • Like 3
blew something out of the pressure switch line and I am up and washing again.
  • Like 3
