I have an old Electrolux frig/freezer TR71/55.
It is about 40 years old and has given (and continues to give) excellent service!
However, one fault has developed.
When defrosting (this has to be done manually – it is not an automatic defrost machine) the water does  not drain away down what seems to be  a  small ‘plug’ hole in the middle of the bottom of the freezer. The water is supposed to enter this drain hole , go down a plastic hose and exit at the end of the hose.
Something must be clogging up this plug runaway. It looks as though it can somehow be unscrewed but I don’t want to force anything!
Are you able to give some advice?
  • Replies 1
  • SWORLD
  • Jeffers613
yes, take hot water in a glass and a turkey baster. try to remove the object by pushing hot water through the hose.
