MVWX500XW0 maytag bravos still not working help
Anna Schwartz
MVWX500XW0 Maytag bravos washer is giving me error codes for lid switch fault and basket speed sensor fault. It is not draining and spinning 90% of the time. I replaced the lid lock switch and the shift actuator, as well as the balance rods. What is my next option. So tired of spending money.
Really need to pull tech sheet out of console and start following the diagnostic procedures. Always test, ensure you know what part has failed before replacing parts.
Anna Schwartz
I did do all the tests even in manual and all that. But think I finally got it. I think it was a wiring harness concetion issue combined with one of the above issues. Reconnect everything for the second time and now it seems to be working... Who knows.
I have on occasion found these units to have loose connections at the motor, causing no spin , agitate etc. Often these problems would be intermittent. So the harness connectors are a known weak point on these. I push the pins back in towards the middle of connector so they engage tighter , with no intermittent short or glitch
