I hope I'm using the search window at the top rt of the home page correctly. I always start a search there but have never gotten a hit while submitting like that.
Customer (my vet.) has KM 110.46742701 showing SUD error. They did the recommended, and I did the recommended- as per the tech sheet. It says then try a rinse and spin... SUD!
I'm leaning toward the pressure transducer or the Central control unit. Only guessing.
I could use a SERVICE MANUAL and any advice from those others here that might have seen this before and corrected it
Thank You all!
Tech sheet
Hi LI-NY.
I actually already have the tech sheet. Hoping for a service manual and any advice on addressing the SUD error.
Anything else in your arsenal?
Just to pass this along. While picking up parts today I mentioned this issue to another tech in the store and he says start with the pressure transducer.
I'll update everybody on how it goes...
The tech sheet is pretty detailed on how to deal with the suds error.
  • Like 2
true, but none of their suggestions were of any help
