I need to remove the glass top on k/a range model#kess907sssoo so that i can access the door lock assy. and wiring, can anyone tellme how to do this. thank you,   peter
Should be able to have access to latch by removing front panel, Shut power off at main breaker - slide unit out 1/3 way - one screw located on each side of panel - open door n 4 screws located under panel - panel will drop down
  • Thanks 1
