GE Advantium Model PSA2201RSS dead/replaced TCO
Hello,
After reading the many helpful topics on the TCO in the GE Advantium, I decided to order a new TCO and see if I could fix mine (completely dead).  When I opened up my control panel, there are actually 3 TCOs, but the bottom one did in fact test open, so I replaced it with my genuine GE TCO.  Still no power.  All of the TCOs check good, and the other two fuses I can see from the control panel test good.  Any other ideas as to what may be my problem?
Most of the TCO's out there don't de-energize the entire machine... so I would start with my meter and follow the 120v AC from the wall outlet, through the "pigtail," and find where the voltage ends. I suspect TCO problems when a failure follows a self-clean or run away temperature situation, in both cases, the TCO being open will be a symptom of the original heating issue, not the source of the problem. Follow the fundamentals and avoid taking stabs at random parts and you will find the guilty party...
Service manual upload pending approval 31-9201.pdf
  • Like 2
Could someone approve this please?
1) I can't locate the file to approve it. Maybe someone else already approved it.
2)Once approved for the library,  you would  have to upgrade your membership to retrieve it.
Oh....OK, thank you.
Domo, for the upload, Brother Chat!
