davenheth43@gmail.com
I have replaced both the mother board and the inverter and my he profile still will not cool. Now what??
  • lvasquez11
  • LI-NY Tech
  • davenheth43@gmail.com
Is the compressor running? If it is and you still have zero cooling you have a bad compressor or some other sealed system problem.
If it's not running you'll need to start by checking voltages to the inverter. It should have about 5 VDC on the small connector and 120 VAC on the larger connector.
