I have a few coin Whirlpool washers CAM2752TQ3 and when the button is pressed for large load the water is not filling the whole tub.  I know that there are 2 switches for this washer a Low pressure switch W10414162 and a High pressure switch W10414164.  Would it be the low or the high switch that would be causing the tub not to fill.  I am new at repairing these machines.
  • Replies 1
  • Budget Appliance Repair
  • Hosski
All the coin-ops of this style, (that I know of), have an option plug to make the rinse water level equal the wash water level.  I'm not positive of what they consider the High pressure and Low pressure switch but the one without an external adjustment is the Low rinse level switch.
It is usually a purple and purple/yellow single wire with a plug connector to switch from one wire to other wire to select full fill rinse option.
In California you are not suppose to change this but I won't tell if you don't.
