Good morning all!
My LG dishwasher is currently exhibiting poor wash performance and intermittently giving an FE code.
I went in to test mode and was able to manually start and stop the fill valve, although it ran to a level of nearly 600 before I stopped it to activate the drain.  The troubleshooting guide I found in the unit said it should stop around 285.
I measured resistance on my fill valve, got a reading of 28ohm which was low so I bought a new valve. Of course the new valve measured 28ohm as well so I didn't install it and now I think my meter may need attention too. :/
Any recommendations on what to do next?  The troubleshooting guide says to replace either the full valve or the PCB. Shouldn't there be a level sensor in the system too somewhere?
LG LDS5540ST
S/N 301KWLR0E496
Thanks in advance.
  • 4 weeks later...
So I put the new valve in anyway because why not?  Everything was golden until this morning, just got the FE error again.
New PCB time?
I still don't understand how the washer knows how much water it is holding.
On the outside of the tub where the water enters there is a case assembly with switches and a float. I would start there. I've seen these get gummed up and cause problems.
  • 4 years later...
AtomicSteve
I have had the problem with the inlet with the water level float and flood switch float getting so full of debris it faults.  I had to remove the whole assembly and flush/clean.  It fixed the issue.  You have to pull out the dishwasher to do this.
Posted (edited)
5 years have passed since this was an issue. I’m thinking it’s resolved by now.
Edited by 16345Ed
  • Haha 1
