Whirlpool Washer LA9480XWN2 Help please!
OK, a little background ...
My old Whirlpool was shaking during the spin cycle, so I replaced the 3 little wear/bearing pads and the counterbalance spring.
But, when I put it all back together and my wife put clothes in it, the machine fills up with water and then nothing.  I've checked and jumpered out the lid switch - and the timer times out.  But the machine neither agitates or spins or drains.  Any ideas?  I must have done something stupid, but can't seem to figure it out!
Thanks much!
  • Replies 4
  • elkheimer
  • lvasquez11
  • Hiroshi
Well, I wiggled the connector at the motor and away it went.  Is there a way to fix that connector or am i going to have to buy the harness?
You could try using a zip tie - add silicone on connector n let it dry
Look closely at the plastic connector... if there is a burn/overheating mark developing, you should get a new terminal and hard-wire the neutral.
  • 2 weeks later...
Thanks guys - I appreciate the help.  The old Whirlpool lives to see another day!
