Dryer had no power to control panel.
Diagnosed faulty thermal limiter.
Checked and cleaned dryer duct, including cavity duct.
Replaced thermal limiter. Now have a faulty safety thermostat (no power to control panel).
What could cause both of these parts to fail quick succession?
Sam
  • Replies 1
  • QualityMike
  • sjsmithjr
QualityMike
the diagram shows 120 volts supply at J2 pin 1 hot (red/blk), J2 pin 2 neutral (white), does not go through thermostat. check this voltage 1st, if not present, suspect unsatisfactory AC voltage or wiring harness. im looking at the service manual for this unit.
