I am looking for the tech service sheet on a FFLG1011MW3 Frigidaire stack unit with inverter drive motor for the washer.  Specifically looking for the procedure to get into the diagnostics.  There are no LED lights, only the horn.
  • Replies 4
  • jay jay
Tech sheet:
Thanks !!!
  • 1 month later...
Good day.
I need a little more help.  Is there a service manual that would help is diagnosing problems?
This unit had a simple leaky inlet valve, but also the lid was locked.  I managed to get it unlocked in the Rinse & Spin mode.
However when trying to run the diagnostics, it would only do 2 short beeps.  I tried numerous times.
So when the new part came in I tested the machine.  First problem ... only the cold water works.  Swapping leads on the solenoid proved that end worked.
Checked for continuity back to the main controller ... OK.  Checked the three position temp switch resistance values against the water level switch (same part) Identical values.  So ... it is either the main controller 137469113 or the interface 137332702.
After a few tries at checking end type circuit board connectors, it quit doing anything except activating the lid lock.
How can I determine which board is the problem?  Tech sheet 137539400A (1206)  wiring diagram 137366600D
jay jay, please start a new topic on this in the Laundry forum and we'll help you there. This forum is for tech lit requests only.
Thanks!
