This fridge cools for awhile then shuts down, it may be hours or just minutes that it works. I also noticed that the lights and fans will power up and down in what seems like a sequence with numbers randomly showing up on the display as if it's doing a self diagnosis. In manual diagnostic mode it will some times show an 02 on the freezer fan and compressor and they won't start, I know that means they are going the wrong speed or in this case not at all.. Then at other times the fan or compressor will show an 01 and of course it does start but always after awhile everything shuts down except the interior lights when the door is opened. Anyone seen this before?
  • Replies 6
  • herfdog
  • lvasquez11
  • Hiroshi
The main control board is suspect on these Kitchen-Aids, the capacitors cause weird failures... Get it rebuilt! Fix-Your-Board or Corecentric can do it.
Hiroshi,
Thanks for the advice.
Based on your model Get Service kit Part number: W10818296. spend  alittle more n get
All new control boards
First of all, i appreciate your input, however, I clicked on the link for the part number you gave and ran the combatiblity test on that website and it said the part listed is not compatible with the model number. Is there some sort of mistake on that website?
the new multi-board kit is getting mixed reviews from the techs I still talk to whom have installed it, your original board is definitely compatible...
Im getting info directly from service bulletins posted by kitchenaid
Based on model n serial  #
