Samsung Fridge Ice Maker not working - RF28HDEDBSR
David Eckell
The ice maker stopped producing ice but I am able to dispense water.  The "ice maker off" light is not illuminated.  I pressed the reset button for 3 seconds but it did not work. I ran the self diagnostic process and it gave me a 39 E error code. I appreciate your help.
  • Replies 5
  • David Eckell
  • howdryiam
  • DurhamAppliance
Service manual defines 39 as an internal icemaker failure. It is likely a short in the heater - the icemaker is cooked. It is important to install the new icemaker with unit unplugged or powered off at the breaker. Restore power only after the new icemaker is installed.
David Eckell
I was afraid that the whole thing would be fried.  Hopefully there isn't a secondary problem. Thanks for your help.
this icemaker is attached to a refrigerant line.  You must defrost the icemaker prior to separaring the line from the icemaker prior to removing the icemaker otherwise you run the risk of destroying your fridge.
David Eckell
I found removal instructions online and it looks like the refrigerant is an oval coil that slips around a metal baffle in the middle of the icemaker. I was able to move the coil out of the way as it was not frozen to the ice maker itself.
Thank you Durhamappliance for that cautionary note - and good work David.
