ice maker not working ,found that water wont fill water in door working
. Pushed test switch ice maker went through cycle but on water, put test meter on fill valve ohmed out valve all good .I ran another cycle test and no 120v to valve. I believe I have a bad ice maker?Is there any other test to check this out ?
  • BradE
  • Hiroshi
  • montrue
These ice makers are high failure parts, they are essentially modular, so just replace the whole ice maker unit, it is the likely culprit
