Hope you guys can help.
I get a CH 61 code and according to the manual I was able to find that indicates a condenser inlet high temperature. It might be a temp sensor on the condenser inlet. And that is all it says. In other parts of the manual it at least gives a way to check various sensors and where they may plug in on the controller. This one has nothing. Testing and replacing sensors I can probably do with a little more information.
Can you guys help? It looks like I can get sensors from you guys if I know which one I need.
  • KeithVW
  • Hiroshi
Is this an air conditioner? Make sure the condenser fan is running to cool the coils, and that the fins are not clogged with debris?
Yes it is an A/C. The motor runs fine and the coils are clean that's why I was looking at the sensor but I don't know how to test it or where it even plugs into the main board.
