Kenmore Gas Cooktop 911.33389890
jjbodean1970
Hello all,
Just this evening immediately after use my Kenmore Gas Cooktop 911.33389890 started having all burners ignitors fire simultaneously on a regular basis with the same frequency of several second delay between firings. All burners still light individually, but all 5 ignitors will continue to fire even with burners being lit.
Any insight as to which part may be problematic for me? I have simply unplugged the unit for now.
Thank you in advance for your helpful reply.
  • Replies 4
  • jjbodean1970
  • Hiroshi
  • johntech
  • evaappliance
 1st thing , Need to check your ground / neutral  on the incoming power .
 Unplug unit over night and see if problem goes away. If moisture enters the circuit it will click till it dries. If the problem does not go away suspect one of the switches.
jjbodean1970
plugged the unit back in this morning and appears to be working correctly, will continue to monitor
thanks for the replies, have a great rest of the weekend
Use cleaning fluids sparingly, if they get into the spark switches, this happens.
