Frigidaire front load washer fills and sits idle.
OkieDrifter
Frigidaire model FWT645RHS0 front load washer. I replaced drain pump that had failed and now washer will fill and not start to tumble. Door lock light is on. if I open dispenser door door lock light goes off and door can immediately be opened. if I push in start/stop knob door light goes off and door can immediately be opened. i can rotate timer dial while washer is on and all that happens is drain cycle starts and fill cycle starts. Before drain pump failed everything was fine.
  • Replies 5
  • OkieDrifter
  • micabay
  • Gnominator77
  • johntech
Take a close look at the sume hose. this part:
Part number: 131784700
Is the air dome connected?  is the pressure hose connected to the air dome?  Is the pressure hose connected to the pressure switch up above?
OkieDrifter
I have checked all of those and it is all ok. the pressure switch is shutting off the water fill, when I remove the hose it overfills. i have checked for voltage to the motor control board and am getting only 35 volts from the timer control. checked motor windings and got 3.4 Ohms. I'm thinking it's the timer not sending proper voltage to the motor control. is there anything else I should test?
You should have 120vac out of the timer at the black side terminal 4 T.
OkieDrifter
Found the culprit, the drum had hit the timer case and the harness plug was almost off the pins.bent the sheet metal back out, pushed the plug back on and good to go. I should have just been more observant.
Make sure you take a look at the tub shock absorbers.  I had one a little while ago same issue as yours where the timer plug was out and the shocks were broken. If you have the older white style shocks they should be updated to the newer kit.
Part number: 5304485917
