Daddy Baese
I have a maytag dependable quiet plus 3 speed washer that got caught on a rug at the motor belt pulley or the item I was washing was too heavy on the spin cycle.. The rug was caught but the machine failed on the large load. I tested the motor with a bypass test cord to the wall power plug and the motor runs fine in agitate and spins and drains. The transmission works ok, I checked the fuse at the door switch and its okay, I checked the continuity of the switch itself and it reads okay. Is there a reset on this machine? At a loss...
  • Hiroshi
  • Thirstytech
  • Daddy Baese
What is the model number? What is it failing to do now?
So it was either something under the washer or in the washer that has caused this undisclosed issue?!
