TorontoGrasshopper
Hi Everyone,
I have a Maytag washer MWHE400WW01  It is the 4000 series are here are the Symptoms:
*  Cannot get any lights on the control panel (touch pad / LED assy)  to come on at all except that the "Control Lock" feature seems to work and light up and chimes
*  When pressing the power button I get 3 short chimes and that is it - nothing else (except the control lock light)  lights up at all - Zilch!
*  Cannot get it into diagnostic mode(s) at all as nothing happens
* I checked the "door switch" (not the door lock switch) and I get continuity across the switch when pressed
* When plugging and unplugging the power cord I get clicking from the CCU
Any common problems that may cause these symptoms?
Thanks in advance
Tom
  • Replies 6
  • TorontoGrasshopper
    4
  • sh2sh2
Have you tried to turn off the control lock?
TorontoGrasshopper
Yes I can turn it on and I can turn it off but that is about all I can do.  It makes no difference if it is on or off.
Remove the bottom panel and unplug the blue 3 wire connector from the motor control board on the lower left, if the unit now powers up you need a new board
TorontoGrasshopper
Need a new Central Control Unit Board or Motor control unit board?
Motor control
TorontoGrasshopper
I did what you said and you were correct.  After removing the 3 wire blue connector the Front panel lite up like a Christmas tree but of course it did nothing but at least it shows the MCU is the problem.  Am going to get another!!   Thx so Much!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
