RMC305PVS00 replaced magnetron back in December. Magnetron went out again in June. Replaced, now it makes a loud pop when ever the microwave is started. It's pulling in the side of the cabinet slightly. Replaced magnetron, transformer, cap, diode. I've double checked the wiring with the wire diagram. What do I do next. I'm at a lost.
  • Hiroshi
  • Jamerson
Pulling in the side of the cabinet? Inside the oven cavity? or the outside of the cabinet that you would see if you pulled the oven out of the wall?
Oven cabinet. It's pilling in the metal cover that covers up the magnetron and transformer.
Yikes, never seen that! There are "wave guide" covers on some models that look like metal and begin frying and popping because grease soaks into them, but metal parts in the oven should not be melting... If they are, just scrap this puppy!
