Manufacturer: Frigidaire
Type of Appliance: Laundrycenter
Model Number: Fflg2022mw3
Tech sheet when I looked it up was incorrect, sheet listed is for range.  Any advice?
  • Nycpas
Uses the same tech sheet as this one for this model
  • 1 month later...
unit is giving slow drain code but unit pumps out right away.  Tested amps on pump and it was low, changed pump even though I was happy with rate of drain and still same issue.
unit spins very slowly if at all.  Motor and tachometer are within spec for ohms.  changed motor control per tech sheet and unit worked for 2 weeks and now back at it again.  I am noticing some oil dripping down shaft near bearing but this is not a transmission model shaft motor and belt.  very puzzled and considering re ordering speed board under warranty.
This forum is for service manual requests. Start a new topic on this in the Laundry forum and we'll help you troubleshoot there.
Guest
This topic is now closed to further replies.
