We get an i30 Error when we try to run the dishwasher.  Electrolux says it's the water pressure valve that gets clogged with debris.  They are covering the cost of the part.  How easy is it to install?
  • GTJQP13
  • johntech
  • 16345Ed
Easy enough. You will have to pull the unit and if I remember right  you can access everything from the side. Then you get inside the unit and add a piece to the hole to prevent it from happening again. Kit comes with instructions.
Thanks!  Part should be here Thursday.  Let's hope this works:-)
GTJQP13, please follow up and let us know how this works for you.
I have a unit that is giving same code and pressure sensor did not resolve the issue. It worked for a couple weeks and then threw the code again
Btw, I see nowhere for this sensor to actually accumulate any debris.
Does your unit have water in the catch tray?
