GE Profile WCXH208A0WW washer - Drum is loose and washer knocks
Hello,
I have a 10 year old GE Profile washer, model # WCXH208A0WW
The drum is loose and I can push it around back and forth easily.  I noticed that after the washer started knocking every time it would start to spin.  I think the issue is with the rear bearing.  Before I start pulling everything apart I'd like to get an expert's opinion on this.  The price doesn't seem to justify the fix.
The part I believe I need is this one: http://www.repairclinic.com/PartDetail/Rear-Drum-With-Bearing/WH45X10007/280742?ss=-x77683435783130303037
Thanks a million!
Walter
  • Replies 4
  • ciwa
  • Hiroshi
The general test for frontloader bearings is to reach your arm into the drum, then place your hand in the center of the spin basket and push upward. If you feel the area at the rear of the washtub "clicking" like there is space between the drive shaft and bearings, and/or it is "roaring" when it spins- you need bearings. You may find that one of the spin tub support arms has corroded through due to LIQUID DETERGENT and that is why the banging is occurring... If you love this machine, I wouldn't buy the back side of the outer washtub at that price... I would spring for the entire drum already assembled, it costs more, but saves you the labor and you start with new supports, bearings, and it is assembled by the manufacturer- you just hang it and hook it up, it is only $100 bucks more......Part number: 134453200
Part number: 134453200 Double check your model number though, I couldn't find a match for it in APP or Repairclinic...
Hi Hiroshi,
Thanks for the response.   I will perform that test and look into the cost versus a new machine.  As for the model number, I double-checked it and it is correct as printed on the label, but I found on the GE website that they refer to it as WCXH208AWW, so there's a '0' removed after the 'A'.
Just one more question. I'm understanding that liquid detergent (yes, that's what we use) is an issue.  Would it be better to use powdered detergent?  I'm not sure I understand why.
Thanks again,
Walter
Powder is much better. Liquid leaves a funky residue on the surfaces it touches- it keeps metal parts damp (promotes corrosion), it is biodegradable (invites bacteria to live in the residue), and no matter what, Physics proves that solids are always more dense than liquids, so you get more for your dollar with Powder.
Always leave the door open between cycles and use powder to keep your machine smelling clean and working as long as possible!
Hi again,
Thanks for the info and yes, the test is conclusive for the bearing issue.  I'll start shopping for a new machine ;)
Walter
