hitechseeker
I have a gas valve number 704504K.
Its a valve that can only be turned by 1/2 turn maximum.
I  am looking for the correct spark switch for it. I do not have a reference to the previous switch, but it looks like switch 704512 would work. The switch is described as firing at 160 degrees.
Can someone confirm that this is the right switch ?
is the 160 degrees measured anti clockwise or clockwise ?
The knob on my switch only turns anti clockwise.
  • Replies 1
  • hitechseeker
  • PDuff
Posted (edited)
According to the part number for the valve provided (right side valve for the Jenn Air gas downdraft cooktop), the switch you've mentioned is correct.
Updated part numberPart number: WPY704512
embedded part number
