markinchico43
My gf's washer won't complete a cycle.  the washer and the timer just stop.  sometimes it will attempt to wash/spin but it is only momentarily then it goes into rest mode.  there are NO error codes displayed.
a few years ago i freed up the clutch assembly.  that does not seem to be the problem now.  the inner basket turns freely and after giving it a spin by hand it does another ~6 revolutions before slowing to a stop.  the drain pump works as it can be turned on in service mode.
the tumblers are difficult to rotate and gf says they turned more easily before.  there is also noise when turning the tumblers...kind of a grinding noisy like the bearing(s) are shot or at least very gummed up.
how are the tumbler bearings accessed and could this be the source of the problem.  i know from past experience and reading many posts that the clutch assembly can result in this scenario (but as i said this probably isnt it) but nothing regarding noisy tumblers or bad tumbler bearings being the cause of this issue
TIA for any help
Mark
  • Replies 1
  • markinchico43
  • Hiroshi
This machine is toast, grinding bearings means you need new ones! Go buy a used Whirlpool/Kenmore direct drive... Or a new Speed Queen. The Maytag Neptune TL has been abandoned by all manufacturers, it is a doomed system and the sooner you get it replaced, the sooner you can get on with your life. Just please, do not replace it with a Whirlpool Calypso!   :fouetaa:
