GE Profile Refrigerator Model PFSF5NJWABB - Possible bad Invertor/main board/compressor?
Dude with a meter
Refrigerator is not cooling or freezing.  Lights are on, fans are on, water dispenser works - main board signal voltage to invertor is bouncing between 4.8 - 5.1 VDC constantly.   There is 120 VAC to the invertor and the compressor windings all measure 6.5 ohms.  No shorts from any compressor leads to GND. How do I know that the compressor is not frozen?  Is the bouncing signal voltage to the invertor normal?  I tried measuring the signal voltage with the signal wire disconnected and the voltage was still fluctuating although it was higher.
  • Hiroshi
  • LI-NY Tech
  • Dude with a meter
  • BrewHobbyTech
With DC and AC voltage to the inverter but no compressor operation it's about a 99% chance that the inverter is the problem.  I've never seen one that wasn't.
I agree 100%  3-6VDC is what the signal voltage should be ...buy the cheapest one GE makes and just swap the gray box if it wont mount the same
Part number: WR49X10283
  • 3 weeks later...
BrewHobbyTech
I don't have good news but I can give a least one suggestion....or ask a question....and then give a suggestion......
Have you tried giving it a swift(hard) kick?
I'm actually in the beginning process of trying to learn how to repair these inverter boards. I have an o-scope from back in the days I went to electronic school........I don't know if I'll be able figure out how to repair these boards, but if I do.......I'd be able to retire soon........hey, I can dream.........
