GE Fridge tbx18spb lower harness diagram
FronteraRepairs
Greetings! Long time reader, first time poster!
I have a GE tbx18spb fridge that needs rewiring... Dog chewed up the bottom harness where there is a three way split on the harness and some other bites near the compressor wiring..
Does anyone have any clue as to where I can get a wiring diagram or anything of the like? I'm burned out. I'll attach some pics for reference to the fridge.
Thanks.
  • Replies 4
  • FronteraRepairs
  • Chat_in_FL
  • PDuff
  • evaappliance
You may already know , but though I had better tell you that refrigerator is one of very few with that compressor to make it much out of the warranty period . I would not put a lot of time or money into this if it were me. I would be very surprised if it were cooling properly before the dog had its way with it . If you are set on trying to fix it ,at least run the compressor and condenser fan to see if the evaporator will frost over all the way.
GE sent out truckloads of refrigerators in the late '80s and early '90s with inefficient compressors, but every so often I'll see one still chugging along.
If you can't find the diagram in the grille, check the download section here in Appliantology.  You may have to enter "ge refrigerator" in the search field, and manually search the entries for something close.
FronteraRepairs
Amazing - I didn't know they stuck these things down below the fridge. I would have never stuck my head down there. As far as I know they don't make harnesses for these fridges so lets see if this puppy frosts again. Thanks!! :thumbsup:
mini-manual
31-5637.PDF
