Bosch SHX3AM05UC DW what is this fault code?
Paige Colbert Van Otten
Using these instructions, "Press and hold “<” and “>”buttons, then turn dishwasher on. Regular Wash light will flash and Quick Wash light will be lit. Press “>” button to start program. Only highest priority fault code will show" I have received the following error code: active and clean are blinking, rinse is steadily lit. Anyone know what this one means?
Thank you!
  • Paige Colbert Van Otten
  • johntech
Active clean and sanitize are used for error codes the rinse is not. Active and clean blinking is a drain pump error
Perfect - thanks! That's what I suspected so I ordered a new drain pump last night.
Replaced the pump last night and it worked! Thanks again
