*Sorry I meant to reply to the other thread. Did not mean to bump an old post and dont see any way to delete it.
  • 2 years later...
  • Replies 26
  • tomD
    13
  • john63
    9
  • Coupe
  • Lighthouse
On ‎8‎/‎4‎/‎2016 at 10:34 PM, john63 said:
Built April 2005
Unplug washer
Set test meter to DC voltage test mode
Place test meter leads into the plug at the RED and BLUE wires
Do not hold or touch the test leads or plug
Plug in washer
Press and hold the SPIN SPEED and SOIL LEVEL buttons
Press the POWER button and release all three buttons
Wait until the door locks (single click sound)
Press the START button once
Is there voltage showing on the test meter? Should be about 127 VDC
If no voltage---Main Board has failed (failed relay).
There's a problem with the part number on your first post---it is not a valid number.
For the WM2077CW washer---two Main Boards were used
The original (does NOT have an option known as TUB CLEAN CYCLE)---is p/n: 6871ER1003F
Later built models---with the Tub Clean feature---will be p/n: EBR32816703
Check your Main Board (remove it from the washer if needed) on both sides for a valid part number and post it.
According to LGs website---your model is listed as using the 6871ER1003F
Both Main Boards are NLA.
As it happens--I have been doing LG warranty (and out of warranty) service for a number of years
We also sell rebuilt LG appliances---so our inventory is fairly extensive
I have several *used* (verified good) 6871ER1003F and EBR32816703 boards in stock---collecting a bit of dust (they're for older models that have long been discontinued)
If you can verify the part number on the board---you can have it NO charge (you pay shipping)
Send me a PM with your phone number---and I'll have my office contact you.
Hi,
Do you have any of the EBR32816703 still? If so can I make arrangements to get one of these from you? my email is ddever85212@gmail.com. Thanks
