I opened up the range top to my oven and now I can't get it to close all the way.  Any suggestions for this model?
Thank you
  • Replies 10
  • 16345Ed
    6
  • smk
    4
  • BrewHobbyTech
I believe there could be "prop-up" rods on each side. Make sure they aren't getting in the way when you lower top.
I can't look up part diagram for you because you provided a bad model number.
Sorry model ok
part 115 is what I was talking about.
6C31A1F6-5439-49E7-876D-97934DD8668A_zps
Edited by 16345Ed
the rods seem to be clearing ok; didn't know if it was a problem that has been seen before. I couldn't find any posts on it though.
thanks for the response and the diagram
There are mounting pins in the back on both sides.
When you removed it you took left side out first.
Put right side pin in first then engage left side pin. Part 118 on diagram I believe.
never mind, the end of the rod was going into the wrong slots to close:bangin:
You found it, good job!
BrewHobbyTech
Congrats......you're no longer a virgin.......
Just kidding man........but I thought it was funny.........
Lol
